- This topic has 6 replies, 4 voices, and was last updated 7 years, 8 months ago by
Doug Odgers.
- 13/07/2018 at 17:13#15901
Doug OdgersParticipantAfter my first 4 weeks I now feel like a veteran.
I have spoken to some very helpful Atalanta owners and one of the themes I am picking up is that sea water is not the enemy, but rain is.
Is that why most I have spoken to either own or have access to, a barn !
As my search continues and I add up my pennies, I never allowed for buying a barn.
Alternatives please.
- 13/07/2018 at 19:12 #15902
Mike DixonParticipantHi Doug – the short answer is no – but……………….you must have a large waterproof shelter. When I say large, you’ll need as a minimum of three feet clear round all sides and ends of the boat plus a good clearance overhead as well as beneath the boat. Then you’ll need room for tools and “stuff”. Having a tarpaulin structure will be fine, but security issues will have to be considered. The other major consideration is power – yes, you can achieve all repairs etc using battery powered tools, but there’s nothing to beat having mains power available for lighting and, in the depths of winter, a bit of heat. But access to a secure barn like structure will bring peace of mind. I’ve rented a ‘barn’ for A1’s restoration at a cost of £100 (including power) per month – worth every penny!
Good luck! Mike
- 15/07/2018 at 12:57 #15905
Doug OdgersParticipantThanks Mike, that is encouraging
- 13/07/2018 at 22:28 #15903
Nick PhillipsParticipantHi Doug
I don’t think so. As Mike says a Barn brings all sorts of benefits, but I do not believe you have to have one.
I had significant deck work to do on Helene and for that work I created a scaffold and tarpaulin ‘shed’ which worked brilliantly. See below. It cost about £1000 initially but has a secondhand value as well at the end (mine is actually loaned for an Airstrem renovation). See below for pictures of mine, and other people’s…
And once you have completed any necessarey renovations and got your Atalanta in good shape, a well fitted cover over a ridge pole (NOT the mast) with frames (polypipe or similar) to hold the cover off the woodwork will keep her in good fettle.
Chris Green had a similar construction for Kerry Piper.
And A17 Gambol has a very fine wood/canvas tent described in the 2013-14 Bulletin, Page 14 onwards.
Of course, the ideal would be to build yourself a Trevor-style Boat Shed, or go one better and pitch for a Murray version
- 15/07/2018 at 12:58 #15906
Doug OdgersParticipantThanks Nick, photos have put things into perspective.
Doug
- 19/07/2018 at 20:43 #15923
Fairey MaryParticipantHi Doug,
I have had Mary since 2012 and not had a barn to keep her in. Admittedly she has not stayed in the same marina more than two winters on the trot. But this winter I would like to hire a barn to bring her back up to spec.
But in general I am happy for her to be on the hard at the marina which gives me flexibility as to which Marina. They provide power and water at a reasonable cost. I also find being at the marina more social and enjoyable.
If I am correct a good breathable cover is sufficient if you have you own parking space. A working area comes into its own when waiting for paint/dew to dry. Don’t confuse a boat that has been neglected for 20 years with one that is regularly maintained. Paints are good now and a cover will extend their lifespan, it may look untidy but if the wood is still being protected it is good. Go sailing!
I am currently finding that it is better to do the ‘lots of small jobs’ like cockpit, spars, electrics and rope work while the boat is in the water, over summer. It leaves the bigger jobs like topsides and hull for either a short season or a barn.
Anyway that is my 2p’s worth and I am still learning.
- 20/07/2018 at 08:53 #15925
Doug OdgersParticipantMany thanks. ‘Fairey Mary’,
That 2p was worth a lot to me and my ruminations as I draw nearer to making a decision on getting an Atalanta. – but have a boat to sell first.
You have really put things into perspective for me dispelled my fears about topsides and coachroof maintenance.
Thanks,
Doug
