- This topic has 4 replies, 3 voices, and was last updated 3 years, 10 months ago by .
At last A90 is afloat after 4 years.
Now the learning begins : the nut and sealing rubber on one of the pivot bolts is leaking, to such an extent that I have bought an automatic bilge pump (I am fitting it this Tuesday ).
I have a suspicion that the bolt is not engaging with the ‘stopper’ flat that stops the bolt continuing to turn when tightening the nut onto the rubber seal. (Don’t really want to correct this until the boat is craned out in the autumn).
Can I :
– take the nut and seal out whilst still afloat ?
– put in a new rubber seal.
– use a different grease? (Currently bog standard marine grease).
– use a combination of oakum and grease?
. . . all help gratefully received!
Doug
01929 792368
