- This topic has 4 replies, 4 voices, and was last updated 1 year, 10 months ago by
David Ewing.
- 30/12/2013 at 18:28#10242
Fairey MaryParticipantI am visiting the boat for a week in January, after the Doggett meet. I hope to repair a hole I made just forward of the hatch. Again with the reefing handle. So as a starter should I use resorcinol, epoxy or that yellow glue that looks like melted cheese. As the damage is near the end I hope to split the ply and replace the small exposed plank. Is this more easily done using a heat gun?
- 31/12/2013 at 21:09 #10243
Trevor ThompsonParticipantThe coachroof and the deck of an Atalanta are made made from three layers of 2.5mm thick agba veneer, each layer layed at 90 degrees to the one below. So it isnt plywood, as such.
To make a proper repair is actually quite easy, when you go about it in the proper way which is described in one of the original Fairey marine drawings. Lots of people seem to want to find a shortcut – but perhaps it is easiest if I describe how to do it properly.
Firstly I would start on the inside. Look at the actual hole. That is the size of the patch you will need to fit into the MIDDLE layer. It is probably easiest if you sand or scrape the paint off around the hole so that you can see which way the grain is running in the lowest (inside) veneer. Now draw a pencil line in a diamond shape about 1/2″ to 1″ bigger all round, making the diamond shape longer in the direction that the grane is going. Hold a metal rule against the line and cut along it with a stanley knife. You MUST use a new blade. Press gently at first and go over the line pressing a bit harder each time until the blade has cut down about 2mm. Now use a sharp chissel to carefully cut out the diamond. You will see the glue line as you cut it away so you will now when to stop cutting deeper. You can cut around the actual hole to make a square or regular shape for the hole in the middle layer.
Cut a piece of paper large enough to go over the diamond shaped hole and press it firmly into the edges, taking care to make sure it does not move. You can draw around the edges with a pencil, but I just crease the paper into the edge of the cutout pressing firmly with my nail.
Cut out the diamond shape from the paper and try it in the hole – it should be a good fit with no gaps. When you are satisfied with the pattern, hold it onto a piece of veneer, and using a metal rule cut it out in the same way as I described cutting the deck. The resulting diamond shaped patch should be a good fit into the hole.
A second similar piece of veneer can be cut out slightly smaller to use to make the patch for the middle layer. Hold it in place temporarily with a couple of staples from the inside, while you draw around it from the outside to get the shape of the hole in the middle layer. Cut that patch out. You can now fit these two patches permanently. Most of us use West epoxy, for this type of repair. It is less temperamental than most epoxy systems. Whatever glue you use it does need to be waterproof and structural. If you use an epoxy (which I recommend) you will need to mix filler powder into the mixed resin and hardener, until it is the consistancy of peanut butter. Fit the inner layer and staple it in place, then fit the middle layer patch from outside.
You can leave the epoxy to set and deal with the outer layer the next day.
How far should you cut back the outer layer?
If you want a professional repair in a varnished surface you have to cut the outer veneer back along the grain each way until you meet an obstruction. Also it has to be as wide as the original veneer. The idea is to leave the finished surface with no extra joins.
In practice if you accept that the edges of the parch will be visible or it the surface is painted than cut out a patch just like that in the inner layer, using the same techniques, and glue it in place.
The repairs can be sanded after 24 hours, and you should hardly be able to see the edges.
If you let me know how big the hole is (small I presume?) I can bring some agba veneer to Doggets for you.
For reference Robbins Timber of Bristol stock Agba veneer.
Dont worry about UV resistance which will be provided by the paint or varnish you apply over the patch.
- 01/01/2014 at 01:07 #10244
Timothy MalletteParticipantYes, I think Trevor’s comments are more to the point. Don’t worry about the glue type just do good work. Also, there is a bit of guidance on hull repairs on plan B12388 if that reference number is still used. Filler powder with the West system epoxy products are what most people use and peanut butter is a good description of the viscosity. Other epoxy products are good too. Be sure to scrap off all the old glue. Most people don’t have any problems with UV and radiation, the effects of UV , radiation and salt take many years usually so as Trevor says it’s not a problem for most people. Wet out the epoxy on both faces of the lamination without filler first for best results.
Also, in regards to your question about the heat gun. It’s ok to heat the veneers before applying the epoxy but not after because the epoxy will “out gas” (creates small bubbles and therefore voids). Best to start with a slightly higher temperature and let it cool down. Humidity can be a factor too, do it on a dry day…. but in general epoxy is very forgiving. It’s easier to clean up the surface by removing the excess after a partial cure rather than sanding all of it after it hardens.
- 15/05/2024 at 13:43 #27409
David EwingParticipant
- 15/05/2024 at 13:48 #27410
David EwingParticipantI decided to give Curlew A68 a full paint strip to assess the condition of the wood, and was pleasantly surprised how sound this 60+ year old boat is. So good, I’ve decided to go for varnish on the topsides. There are a couple of small fibreglass patches which I plan to remove and replace with the top layer of Agba veneer.
Does anyone know of a supplier in the Midlands? The closest I can find is Robbins in Bristol, who now only offer full 4×8’ sheets.
Thanks
