- This topic has 13 replies, 4 voices, and was last updated 2 years, 9 months ago by .
I have owned A142 for 23 years and in that time have had the rudder control cables break four times. On the first occasion my co-owner and a friend were positioning from Gairloch to Ullapool and on a lee shore when the break occurred. It was only due to their quick action and ingenuity that the boat was not lost. After that I mounted the emergency tiller to hand in the rear cabin. The cable that failed was galvanized steel spun over a natural fibre core and appeared to be original. I made up my own cables from some wire rope I had which I found about to fail while moored one day a couple of year later. I checked the blocks, replaced two and adjusted their angle to ensure a fair run. The next failure was coming into Whitehills in the dark with a N’ly wind and swell. We had dolphins playing in our wash but the enjoyment was short lived when with two cable to go we only had one rudder cable attached. About three yaers ago I took professional advice and had 5mm cable made up with 7 X 19 stainless steel but imagine my horror when at the beginning of last season with a week to go to launch I found these to be held togther by only a few remaining strands. Having replaced them I was happy that all was well until a week ago when carrying out a routine check I found some broken strands on cables that had only done one season, and a short one at that. The only other relevant factor is that A142 is in a swinging mooring with the helm lashed so there is constant fretting as she swings.
I have received the following advice and suggestions.
1. The stainless steel case hardens with use so might not be the best material and using galvanized wire rope might be better.
2. Have new cable made form 6 X 36 SS
3 Have cable made from dyneema.
4 Just use terylene rope.
Does anyone have any suggestions, comments or ideas?
