- This topic has 3 replies, 2 voices, and was last updated 12 years, 1 month ago by .
Does everybody still like the copper resin anti-foul and resinstore in particular. I put a sacrificial anti-foul on Mary last year and what hadn’t warn off was removed by the marina when she was washed down.
Towards the end she was getting a bit rough underneath. There is one patch on the keel strip that looks “eaten” should I cut that out. It may just be scratches but it looks a little too wormy.
I assume the process will be to smooth the hull down. It has been treated with west system resin. Making sure it is clean then prime with their safeguard primer then to apply the copperplus. So how much will I need? If somebody else has done the comparative maths does resinstore with discount still add up.
