- This topic has 1 reply, 2 voices, and was last updated 5 years, 8 months ago by .
How to insert a photo or other image
Adding a photograph (.jpg or .png) to your posts is relatively simple, if not the most intuitive.
The example below uses a ‘Reply’ screen but the approach is the same if starting a new ‘Topic’.
Position the cursor where you want to insert the image.
Make sure that you select the Visual tab and click on the image icon.
After clicking on the image icon the following pop-up box will be presented. Enter values as indicated.
Pressing OK will insert the photograph.
Having inserteed a photograph you can change the caption and / or the size of the photo by clicking on it. This will re-open the ‘Insert/edit image’ pop-up as above.
