- This topic has 3 replies, 4 voices, and was last updated 4 years, 7 months ago by .
I wanted a way to control Helene’s whipstaff while I was otherwise occupied, and thought about the peg-board and belaying pin system I had seen on a Maurice Griffith Golden Hind. After a few iterations I had a working model, using 11mm doweling. The only problem was that if I leaned against the dowels they broke. I then though about using heavy-duty Velcro, and it works a treat.
I was also interested to see if I could use an 18v portable electric drill to lower and raise the keels. A local engineering shop used the hand crank to make a bit from mild steel. It takes about 20 seconds from fully up to fully down. You just have to keep a good hold of the drill!
